help with sa22 non turbo diff in rx4 coupe 12a
Started by dr50376272, December 13, 2010, 08:05:15 AM
Ray
Hi David,
It should fit no problem. I\'m running an FB LSD in my 12a axled RX-4, the length of the nose is about the same, so original propshaft can be retained.
Regards
Ray
dr50376272
RamoNZ
David, did you fit decide to try to find this diff before or after you \'pimp-
slapped your \'ho\' into line?
http://www.youtube.com/user/1973mazdarx4coupe#p/u/26/9Ttkc7SSjuw
dr50376272
Quote from: RamoNZ;732974David, did you fit decide to try to find this diff before or after you \'pimp-
i sincerely wish to apologise for my attempt at humor. i was only asking about my mazda rx4 coupe videos. please accept my apologies; free speech should not be tolerated! best regards to you.
dr50376272
Quote from: Ray;732634Hi David,
Regards
Ray
thanks for that, i think ill use the sa22 tailshaft as my rx4 is auto. ill be using a sa22 gearbox as well and throwing in either a 12a 4 or 6 port which are becoming impossible to find here in japan. i would love to have gone 13b 6 port but are not here in japan.
RamoNZ
Free speech is one thing but the dribble you are coming out with borders on downright nutjob.
Scratch that, you are well over the border. It\'s not taken much research to see that you frequent forums starting out reasonably compus then tending to start spouting filth and depravity.
Spend your time and money seeing someone to talk through your issues. Just my 5c.
