FC 4 Pot Calipers - Pads?
Started by haywes, November 15, 2010, 02:22:07 PM
haywes
I\'m just after a bit of info as I\'m away from my FC at the moment - Did all FC\'s (inc. EGI) have the 4 pots? I need to buy some pads (as mine are almost non existent after my last track day!) and as far as I\'m aware there seems to be just one the same for all calipers for the FC. Were there different years with different brakes? I\'ve got an 87 EGI with the 4 pots so if they\'re from a different year I\'ll need to know to get them instead.
Cheers :driving
dthebuk
If you\'re sure you ahve the bigger brakes then they should be the same as the fd ones take the same pads etc.
I\'m sure someone else may know better though
:burnout
TiddlesRX7
FD and FC pads are the same :) I bought some from MRP. They are made by Racing Brake and were just under £150 for front and rear iirc. Can\'t fault them either they were much better than standard pads on the track plus they are fine on the road.
