Hunting idle with Idle Control Valve on?
Started by leeroy_25, October 17, 2010, 09:19:51 PM
leeroy_25
Hi Guy\'s I have had my idle valve disconnected for a while as it doesn\'t seem to work? It is not the valve as I have tried 3 and they all do the same. basically when the car warms up the idle goes realy high and hunts like hell. So I am guessing it is either a glitch in the Apexi ECU or maybe a dodgy bit of wiring to the idle valve?
Anyone had this before and cured it?
Can someone confirm what the two wires are on the plug to the idle control valve? I am guess a signal and an earth? If so I might try earthing to the chassis to see if it works on the off chance!? I cannot find a wiring diagram with this in??
Lee
mj2326
My rx8 was doing this about a month ago my mechanic friend suggested it was to do with the induction kit fitted it was sucking in warm air and the MAF sensor acts as a thermo-probe and doesn\'t like it so causes the revs to go all over the place. I had this kit fitted for about 6 months and never had any problems but only the other month if I drove it hard it managed to stall itself 3 times
I have now fitted the AEM cold induction kit and after a good drive when i stop the vehicle now sits at 800 rev/min happily. Also you could try having the MAF sensor tested
Stratos blue 231 55 plate, Ecu yellowstuff pads and brakes all round, AEM cold air intake, Front cusco strut, Toyo sport exhaust, manifold and ECU remap, R Magic rear spoiler.
leeroy_25
Hmm?? Interesting but it is perfect with a manually adjusted idle and the valve disconnected so I guess that rules ot the MAF sensor?? I could leave it like it is but I do like to fix tings when possible!!
Lee
a.tapos
sounds like an air leak into the inlet manifold/piping after throttle body.the o2 sensor sees more air and puts in more fuel which picks revs up then ecu pulls it back down creating a hunt.
a.m.t@hotmail.co.uk
trotter
Quote from: a.tapos;724798sounds like an air leak into the inlet manifold/piping after throttle body.the o2 sensor sees more air and puts in more fuel which picks revs up then ecu pulls it back down creating a hunt.
i had same symptoms with a coincidental problem.
1) Throttle body o-ring had failed so had a bit of a leak
2) Air temp sensor was intermittently failing leading to cyclic hunting mentioned above
Work hard, play hard house :D
RXSpeedy
I had this problem when i fitted my PFC, in the end i removed the pfc from the car until now as im going single. Does your speedo stay on 0mph? as mine jumped the 26kmh even tho the car was stationary lol.
leeroy_25
Hi Guys.
Would the problems not mentioned still result even with the idle valve unplugged? I might try and get the inlet pressure checked see if I can detect a leak. I gather with a lot of mods the O2 sensor should really be disabled anyway so if mine is not that could help/cure the problem?
Lee
SiH
Is it an FD? If so I can 100% confirm it\'s not the MAF!
Mine did similar after I removed the hot start system (not permenantly, I was fault finding) but then sored when I replaced it - very strange.
First suspect on a dodgy idle was always an air leak. Howeve,r I also had issues when one of my turbos was going - oil in the inlet combined with the water injection spray and created an emulsified goop that pooled in the throttle body, blocking up the ICV passage. Cleaned out and all was well again.
leeroy_25
Thanks for the info.. The whole thing has had a rebild recently all be apart and cleaned. Single turbo is all healthy as far as I know??
I will first check for a an airleak and see if a gasket is not sealing properly they were new but you never know!
a.tapos
i`d say even more likely to be air leak if its had a rebuild as alot of inlet/throttle body gaskets are disturbed but not always replaced the ecu can use fueland ignition to change idle so idle valve is not the only thing that controls it,
ive known primary injector seals to leak air after rebuild,
run the engine at idle then spray brake cleaner around all of throttle body and manifolds and see if revs change.
a.m.t@hotmail.co.uk
BlitzBoy
If you cant find an airleak then disable the 02 feedback, most likely the O2 sensor is toast by now and needs replacing, the sensor is over 15 years old in most cases
As been said above with you idle control valve enabled, the 02 sensor sends a reading to the ECU, ECU changes the idle fuel mix, then the ECU tries to control the idle via the valve, if the 02 sensor is kaput you will also get hunting issues
Rotorstock winner 08,09
New Project
"el fénix" RX2 by Mark & Mark
leeroy_25
Thanks guy\'s I will try the old clutch cleaner trick. I forgot about that one! If not I will get a smoke test done on it and make sure O2 is disabled!
Lee
