single turbo help
Started by lotuscorsa, October 23, 2010, 10:51:18 PM
lotuscorsa
hello all ,just bought a single turbo for my 1994 twin turbo.
whats involved in fitting this.i will uprait the fueling get it mapped i just wanted to know about the birds nest and solinoids cheers
PGiljevic
There is a ton of work to do it neatly, just depends how fussy you are.... :Thumbs-up
"Can\'t be defeated!, don\'t know the word!, shoulder to shoulder!, we\'ll fight the world!, we can\'t be beaten!!!"
Aubec
This definitely feels like a \'search\' response is justified...
But, in the interest of being reasonably helpful:
Figure out how to plumb it in (manifold right size and shape to make turbo fit, downpipe to mate with midpipe, outlet to mate with your intercooler)
Sort out turbo cooling (oil lines- probably need to blank one of them on the block)
Sort out charge air cooling (Standard SMIC won\'t cut it!)
Sort out fuelling (FPR at the minimum, ideally larger injectors, bigger pump)
Sort out boost control (wastegate, boost controller)
And a remap (assuming you already have a PFC?)
Does that help?
Aubec
1995 UK Silver FD
lotuscorsa
Quote from: RICE RACING;722788There is a ton of work to do it neatly, just depends how fussy you are.... :Thumbs-up
very fussy
lotuscorsa
Quote from: Aubec;722810This definitely feels like a \'search\' response is justified...
Does that help?
plumb it in i have the turbo ,manifold,oil pipe ,external waste gate and down pipe
i am sorting out a front mounted intercooler
fueling will be getting better pump and injectors
i have a boast controller
and will be getting a ecu
i just wanted to know what to take off the standard twin turbo engine eg rats nest ,air pump what else cheers
