Rex friendly MOT near cheltenam and gloucester area
Started by FD3S Efini, July 10, 2010, 02:38:06 PM
MaLicE
im from bourton on the water mate! yeh rotorstock sounds good, as long as im back on the road by then!
FD3S Efini
mine is an L Reg so its 1993 so should be good on that front, on another front i just had a look at my pim voltage and on all options they are all at 50% what does this mean?
Kris
FD3S Efini
just googled bourton on the water mate and its only down the road looks pretty nice aswell maybe me and the wife will have a butchers round there because we are still new to the area, if you need a hand with anything mate gimme a shout because im keen to learn plus i aint to bad with a spanner lol
Kris
MaLicE
cheers mate :) my car is at my mates garage atm (if you need any work doing etc that you dont fancy doing yourself he is good and has built a couple drift cars :) ) i have been putting the engine in etc which hopefully it should be running this week! then when i get it home i have a few things like water injection etc to fit so if you fancy coming over for a look give me a shout :) if your on facebook add me :) James Dirkin
also if you and your wife wanna know anything about the area and places to go for a day out etc i will give you some ideas :)
FD3S Efini
yeah i would be interested to have a look iv not really seen many rx7\'s on the road or near me so id be interested to have a butchers if thats cool, plus we will definatly give you a shout for things to do,
il add you on facebook my name is kris walsh just incase you wondered which random added you lol
Kris
turbotoaster
Quote from: FD3S Efini;703867mine is an L Reg so its 1993 so should be good on that front, on another front i just had a look at my pim voltage and on all options they are all at 50% what does this mean?
Kris
when the car is idling, what % does your injector duty say?
FD3S Efini
injector duty on idle is around 6 or 7 percent on warm up its about 8.5 ish
Kris
turbotoaster
hmmm, very strange, did the car come mapped or is it on a basemap?
if your really new to mapping you can map using pim voltage, thats how i learned at the start, then you move onto the inj map once you have learnt the basics.
that should in theory be at 100%....there are 2 parts, on that has rpm and the other that has voltage, can you check both to see what they say, that might give us a clue
FD3S Efini
yeah the car has been mapped il check those other readings for you 2mora
Kris
Jus
Hi Guys,
Please could someone help.
I know this is a rather old thread but I just need to check something with you.
I own a modified single UK RX7 FD and as a requirement of MOT, I\'ll need to do the idle, fast idle and with a cat fitted.
1. In the pim volts % do i just change 1000, 2000, 3000 rpm to cover these tests? I have done the 1000 and got down to around .3-5 Co @ 75% do I just do the same for 2000 and 3000?
2. And will the motor be ok and not DET whilst trying to move on and off the brake testers with these low fuel settings?
Cheers.
CharlieP
Maybe threads like this need to be kept on the down low?
A little bit like posting up high speed videos on youtube
Jus
admins, as i dont want to keep an old thread active or wrong message, please delete my previous two posts. If someone could PM me the answer it would be great, Its probably a YES to both questions.
Thanks.
