T11 Cab - wipers
Started by johnf, October 19, 2010, 06:06:53 PM
johnf
My wipers seem to have a mind of their own
Sometimes they just won\'t work.
If I turn the engine off and then on again to the point where the instruments light up, and turn the wipers on they work and will work ok until I turn the engine off.
Loose connection, faulty switch or a common habit?
John
Quote from: johnf;722066My wipers seem to have a mind of their own
John
John,
Sometimes my wipers don\'t work - but a wiggle of the ingition switch gets them going - it sounds like that\'s the fault you\'ve got.  It seems to affect the roof motors as well - since they are both on the same ignition switch circuit.
