Aircon matrix behind dash?
Started by stew, September 15, 2010, 09:25:55 AM
stew
Hi all, does anyone have any photos of the matrix and it\'s mounting points behind the dash? I\'ve removed everything apart from this part.
I\'d just rather know where or how many bolts are holding the thing in place.
Panjy
Don\'t have any pics but its sat right behind the glove box in a plastic casing. Casing is held in by a couple of bolts / screws (can\'t remember).
Split the casing (held together by a few screws if i remember correctly) and it drops out.
Its not a hard job, i did it in an hour and i\'m not quick at anything :yes
Aubec
Just two nuts.  One below it in the passenger footwell, attatching it to the bulkhead.  The other is a 10mm (IIRC) tucked right up high under the glovebox: take the glovebox out, look up the top left of the aircon matrix box, past the thermosensor and you might just see it.  You\'ll need an extension to get to it.
Aubec
1995 UK Silver FD
stew
