Rebuild Kits
Started by FD3S Efini, March 30, 2011, 05:55:50 PM
FD3S Efini
Just on the look out for rebuild kits and need some help deciding
I have seen the Atkins Rotary ones
I have seen the mazda ones aswell but they are sooo expensive,
im using standard mazda tips and somewhere to get these would be good aswell,
what is everyones views on the kits above?
Kris
davehg
i have used both kits in various engines for people but would always use genuine mazda parts in my own and would recommend it in others.
Check out Mazda rotary parts, they now do full kits, I would go with the Mazda OEM seals, they have gone through millions of pounds worth of testing, yes they are more expensive, but its not like you rebuilt it every week!
FD3S Efini
Yeah the kits are 1900 roughly and unfortunately that is a bit to much,
Regardless I\'m guna be using the stock Mazda tips
Would like to hear more about the Atkins kit to hear other people\'s experiences
Kris
davehg
call tim at rx motors he also sells these and may be able to do it for less
FD3S Efini
davehg
yeah, he stocks pretty much everything you should need
FD3S Efini
I will give him a shout and see what he has cheers
Kris
TRIND-FD
What you will find now is , that by the time you add on import duties etc it\'s nearly the same as Mazda , Clives/MRP
 kit covers everything you need, you might aswell do it once and do it right.
Keith.
V8 fd\'s rock :cool
a.tapos
There isn\'t a cheap kit really,rotechniks keep Most bits and are good to deal with
Pineapple racing do great kits but may get stung with tax I\'ve used them before
Never used atkins,would be interested to see someone here talk about them
a.m.t@hotmail.co.uk
Buy a cheep kit and you will end up rebuilding again
