Ignition upgrades
Started by damehyndman, June 15, 2010, 01:05:00 PM
damehyndman
Fair point, but if I need to replace the coils, blasters would be a hell of a lot cheaper :Giggle Are the blasters a straight swap for the existing coil pack?
Mazdarotaryparts
Hi Dame it may help to know that in 8 years of selling Magnecor leads we have only had one complaint about a split boot on a set that was around 5 or 6 years old,
We have worked with Magnecor over the last year or so to make the ends even better on the product and currantly average selling 8 to 10 sets a week and have done for a long time,
We now even have some Mazda dealers buying Magnecor on a regular basis as the stock leads let water up the ends and Magnecor leads won\'t.
Hope this helps
REgards
Clive
Mazdarotaryparts
Racingbeateurope
Racecarbattery
shyauto
REVIT93RX7
The supra pump would be ok.  Why not go with a Cosmo pump.
up&coming
alot of us in the states used to use the MSD 6A we used 2 boxes for leading and one for trailing. but they burn up pretty quick
if you going to think about going with msd look into the CRANE CAMS HI-6  setup.
there alot stronger and can deal with heat and vibration alot better. but there also as big as the msd units. and hav went out of buis. so if you can get a new setup from them if anything happens were on are own.
new ignition to go with now is the ARC-2 from Dynatek, these units dont heat up so much, there small so you can mount them anywere, duel channel so one cdi will run both leadings. cheaper then building any other setup. and if you ever want to think about AI injection youll always have enouph arc so you wont have to upgrade anything..
the msd is good but its older tech. and they do burn out.
just some food for thought
