Where exactly is located....
Started by michaelb, June 09, 2010, 04:07:06 PM
michaelb
Hi All
My 96 FD badly needs a service, I am taking it to a non RX7 specialist ( good garage anyway- used them before for minor things) as I can not get hold of the mechanic I usually use.
Where exactly is located the petrol filter and does one really have to take the elbow to change the sparkplugs?
Regards,
Michaelb
AtomicRex
The fuel filter is a ..... to get to and is up near the diff
And no you don\'t need to take the elbow off...but it is easier to do it that way, and it is only 4 bolts that attach the elbow to the throttle body.
michaelb
Hello mate
How are you?
How is racing?  Do you have dates when you are next on the track?
We still fancy a trip to see you race and make a day out of it, you are on the way to Bath, right?
The car has got to go up to get to the fuel filter right?
Is it visible once jacked up?
Regards,
Michaelb
jackaleks
i\'ve always found the plugs easier to get out from underneath the car, takes me around ten minutes these days!
the fuel filter isn\'t visible, at all; you can just about see the bracket that it\'s mounted to. the best way to get to it is to lift the rear of the car up and hook a socket over the top of the rear sub frame, you should be able to get the bolts out from there (have fun getting them back in :)).
michaelb
Quote from: jackaleks;698677i\'ve always found the plugs easier to get out from underneath the car, takes me around ten minutes these days!
Hi
I took the car to a non RX7 garage and they did have fun firstly trying to locate the fuel filter secondly changing it
It took 2 mechanics and some swearing to get the job done LOL
I took the advice of telling them to remove the elbow and they still took a little while to change them
2 hrs but £60 cash – not bad, but now they noticed that my de cut silenced mid pipe is blowing – more money
Regards,
Michaelb
jackaleks
Quote from: michaelb;698705Hi
Regards,
Michaelb
£60/2 hours isn\'t bad actually, it took me twice that to do the fuel filter by myself. i only had a set of chunky 1/2 inch ratchets which are nigh on impossible to fit in small spaces!
