Handbrake
Started by leefitz, June 17, 2010, 06:04:31 AM
leefitz
Hey, what\'s the best way to set the handbrake to get the best results?? I did do a search but didn\'t through up much. Cheers
Japan Life = Better Life
turbointhebrain
I think they are all much of a muchness, just really depends of the condition of your rear calipers and if you have the right pads
leefitz
New but standered pads andthe disks are in v good shape, very little ware. How do you adjust them at the caliper??
cr33ch
have you already tried tightening the nut on the handbreak handle?
turbointhebrain
Cables= no good, hydraulic wand all the way!
Leefitz where do u drift? Nuts corner/bishops court?
cr33ch
if your drifting then yes hydro is the only way but their perfectly good for parking when tight
leefitz
Drift up at bishops court bt only been up the once,  hopefully headin to the next one on the 4th.
Hopin to get a hydraulic handbrake at some point but don\'t have the money at the min. Not to worryed for i got on well enough without it but will try and get one for the next day after July.
I did adjust t at the lever th last time but was wondering am I able to get better results from the caliper, it\'s a free mod
