Webber 45
Started by mpk490p, May 16, 2004, 12:41:59 PM
MikeLMR
I had thought about it, but I like the idea of a DCOE as its a fairly easy change and the parts are available off the shelf.
What sort of set up would you suggest for a 12a ?  I have always quite liked a setup i saw on the US board using a racing beat lower manifold with a 2nd gen dynamic chamber, UIM and throttle body setup used (I think that was the setup but I may be wrong as aren\'t the injectors in the LIM ?? ) .
a carb still appeals to me though as it may be a harder to setup and maintain but its fairly easy to diagnose if you have a major fault.
bill shurvinton
DCOE manifold with motorbike throttle bodies gets my vote.  One day I\'ll get around to a 4 barrel arrangement.
MikeLMR
is this the setup you are running on the westie  ?
How do you go about mating the throttle bodies to the manifold ... just had a quick look on Ebay and M/B throttle bodies don\'t seem to have a flange to bolt them to anything.
how does the megaquirt system determine air flow ? does it require an air flow sensor of some sort or is it mapped using pressure sensors ? (I\'ve only just bought a car with injection so its still a bit new to me :) )
Thanks,
            Mike
Cycaduk
would there be any benefit to running split DCOE carbs as per the old mini\'s/
bill shurvinton
nah the westy uses a butchered 50 DCOE as that is all that I had at the time. However I am seriously considering the lake cities plus bike TBs for the series 2 if I ever get it going again.
MS can use either a  TPS based strategy or a MAP sensor. has run on a number of rotaries now with good success.
In terms of airflow a single barrel per rotor will flow enough air. However running 4 barrels gives you the following
1) a slightly straighter shot at the ports which might be worth a couple of HP
2) the ability to run more radical secondaries and use a progressive linkage or the fly by wire butterflies on modern bikes
3) Bling.
So no need for most applications, but as ever I\'m not practising what i preach :-)
MikeLMR
QuoteOriginally posted by Cycaduk
IIRC split 40\'s are used to get the intake runners as straight as possible on the mini\'s siamesed inlet ports. Split 40\'s are also used on a few cars for road rallying as the rules limit to twin chokes but an advantage can be gained by the positioning of split carbs.
I wouldn\'t have thought split carbs would be an advantage but a twin carb setup like the lake cities one would be.
mpk490p
now i\'m confused have i done th right thing or should i have gone injection? seems like a lot a grif and ive always got a bit more kick with a carb?
i found a lower mainfold for £40 +p&p so should be going soon!
bill shurvinton
Like for like induction length a carb will give the same HP as EFI IF and only IF they are tuned properly. I only know 3 people in the UK who can tune a rotary on a DCOE properly. Pip is one of them. There may be others, but I haven\'t found them.
What EFI gives is
- more flexibility in the inlet design
- Better low throttle response
- more MPG
That first point is what allows you to optimise for higher HP with EFI.
Bill
mpk490p
Well I\'m hoping there closer as they have come off a running car, but I will be going to pip\'s for a tune up to make sure everythings ok, the engines not been run properly for a few years (it starts ok just has\'nt had a run out)
