Half bridge compression
Started by turbotoaster, May 24, 2010, 04:25:34 PM
ad4m1
maybe uve heated it up a lot and warped the apex seals
turbotoaster
its only ever ran 10psi of boost up to yet, never been above 100c water or 47c air temp.
Surely if the all the seals are warped id be down on power, ill see what carl says to my last question
its running fairly rich aswell so cant imagine it would be that.
Will find out shortly anyway when steve finishes his race engine, plus he will fully cover me until i stick a massive turbo on anyway so if it does turn out theres a problem he will strip it down for me.
HaywardRotary
If the engine starts hot or cold and also under boost and load it runs fine then dynamic compression will be fine too,If seals are warped then it will be hard to start especially hot,also you can end up with pre-ignition in that state due to combustion gasses getting into the chamber following and causing it.
Regards
Carl
Single turbo conversions.
S
turbotoaster
thanks for you help carl.
You dont happen to have any second hand airpump delete pulleys do you, dont mind if greddy or ebay version
HaywardRotary
Quote from: turbotoaster;695861thanks for you help carl.
Sorry,I don\'t have any.
Regards
Carl
S
