Copper washer size - clutch master.
Started by Prof, April 28, 2010, 10:39:50 PM
As per the title - does anyone have the size of the copper washer that\'s on the output of the clutch master cylinder.  Ideally the FC one - but I think the part may be common to the FD as well.
Thanks...
TiddlesRX7
I\'ve got a box fresh master cylinder in my car waiting to go on. Only trouble is im parted from my car till friday. I\'ll have a look then and get back to you if you havent found out by then.
Aubec
Quote from: Prof;690417Cheers :) - I know the nut is 23mm
Yeah, and isn\'t that a swine to get a socket for!
Aubec
1995 UK Silver FD
