Door wont open from the outside!!!
Started by JTW86, April 25, 2010, 01:16:42 AM
JTW86
Have abit of a problem, My driverside door wont open from the outside!
When i pull the handle it doesnt have any "bite" could something have came loose from the inside?
ATM i need to open the door from the inside via the passenger side.
John_Hudson
Try getting the door open then pulling the plastic cover from the inside.   Underneath should be x2 10mm nuts, undo those and the outer handle will pull away, leading up into the handle should be two rods whick hook into plastic surrounds connecting to the lock and handle release, check to see if they have come loose
JTW86
Thanks, I\'ll have a look tomorrow.
Brett
Sadly I\'m willing to bet the inner castiung that the hook is connected to has sheared off.  This is very common now as the FC\'s get older.  It\'s not too much of a job to fit a 2nd hand door handle - just a bit fiddly. :wave
Brap Brap Brap Brap
NeilSR
Ive just had exactly the same problem on mine snd had to replace it. Cost me £30 for both sides. About an hours job all. In but simple to do
