Gandys FC
Started by G@NDY, December 01, 2009, 05:30:57 PM
G@NDY
Mapping is booked for the 30th ;)
Quote from: G@NDY;688368Mapping is booked for the 30th ;)
Oooo :D
What boost level are you going to run? Would be interesting to compare the T78 with the T88 when mines fitted :)
G@NDY
First year im only planning on running on the wastegate spring so 10 psi.
lee mills
Should still see a nice healthy bhp figure:Thumbs-up Good luck with it
captainbizzaro
Good luck with the mapping mate-try get some video footage....
