electric arial not working
Started by davehg, May 17, 2004, 08:53:26 AM
davehg
ive just tried to wire in a double din unint and ive connected the antena wire but the arial wont come up, any ideas guys?
Donato
Got a voltage tester? If so check that power is coming out of the stereo to the antenna, if it is then you would have to presume its an inline fuse or the unit is fecked...
davehg
where is the fuse for the ariel located?
Donato
If there is one it would imagine it will be inline, and i would imagine near the stereo. Have a look behind and trace the cable as far as you can....
good luck
davehg
ok ill have a look tonight, tonights aim is to convert the speedo to mph
