best product for removing scratches
Started by kiwi-mick, April 25, 2010, 08:34:25 AM
kiwi-mick
think i saw someone comment on a thread on here about some sort of compound that was good at removing scratches/ refurbishing old paint work
anyone have any suggestions?
Ian65
I think t-cut is as good as anything unless your going to mop the car in which car get some professional compound.
It\'s difficult on a metallic paint finish, I\'ve found most compounds for these finishes are very gentle so that they don\'t remove the clearcoat but by being this way, they are as good as useless really.
Unless anyone knows any different..
My metallic black RX has loads of tiny scratches in the clearcoat, I\'d love to find some miracle stuff that restores it.
Anyone???
kiwi-mick
Ian I don\'t supose you know a supplier of the K3 sunbeam silver do you.
think Dave said he\'d got a few aerosols but the quality wasn\'t assured.
rossonza
meguiars scratch x much harsher than t-cut ive found.
email @ rossonza@gmail.com
1984 FB series 2 in gold
Marcrs
Meguiars scratchX 2 is much better than the original, it has smaller particulates to break down.
T cut is quite harsh, but used wet it can be ok
I use Meguiars Ultimate compound - I find it very good, and it takes a bit more effort, but won\'t do any damage :)
I also use 3M Finnese-It and Perfect-It, but these need to be used with caution.
You will never remove a scratch, only put a radius on the edge of it, making it appear less obvious.
Meguiars Swirl remover and/or ultimate compound will sort out your small swirls in the clearcoat - and then be careful not to add more when you wash it, chamois it etc.
Marcrs
#5
kiwi mick - I notice you\'re in Tonbridge??? If so, I\'d be more than happy to get together at some point, I have plenty of good compounds etc, and a wax wizard polisher ;)
This is my 323...
kiwi-mick
Quote from: Marcrs;690131kiwi mick - I notice you\'re in Tonbridge??? If so, I\'d be more than happy to get together at some point, I have plenty of good compounds etc, and a wax wizard polisher ;)
This is my 323...
sounds good mate thou i\'m not too reliable at present have a 2 week old baby and a toddler, need to strip a series 3, move loads of gear,go to work, help around home and build a two story extension and a single story extension to our home. not to mention manage everything else around here. i might just take you up on the offer in a few weeks hopefully everything will settle down here soon
thanks mick
Marcrs
I\'ll help you strip your series 3 ;)  although, you might end up with less parts than you thought...
no worries mate, give me a shout anytime :)
Swanny_UK
Depending on the type of scratch, its depth, the type of paint etc would determine the approach I\'d take.  I\'d have a look on the Detailing World forums - very useful.
