Caliper repair kit for front of EGI??
Started by MrHanky, April 04, 2010, 03:51:58 PM
MrHanky
Hi,
Just wondering if you can get caliper repair kits from anywhere in the UK?  I have noticed on other threads that you can order from rockauto, but unfortunately I need to get some before next weekend as I am doing a trackday at Mallory on Saturday.
Mark
MrHanky
Thanks very much, do you happen to know if it contains the caliper pins?  If not I will give them a call tomorrow.
Thanks again
Mark
Quote from: papercutout;684573Here you are fella:
http://www.biggred.co.uk/mazdashop.html
papercutout
Quote from: MrHanky;684671Thanks very much, do you happen to know if it contains the caliper pins? If not I will give them a call tomorrow.
Thanks again
Mark
The set I got was rubber parts, dust seals and the metal clips to hold them on - they don\'t provide any pins
MrHanky
Doh!  thanks anyway guys.  The pins are the bits I need :(
I will give them a call to see if they can supply these.
Mark
dthebuk
these front or rear callipers?
if theyre fronts you could pick up some fd ones and rebuild them. just a thought
:burnout
MrHanky
Quote from: dthebuk;684753these front or rear callipers?
Fronts.  Are they the same then?  Or just same sort of size?
Mark
dthebuk
same in terms of performance and size (they take the same pads).
though they\'re less likely to seize and slightly easier to work with
:burnout
MrHanky
Quote from: dthebuk;684780same in terms of performance and size (they take the same pads).
Brilliant, thanks for the advice.  Will see what I can get hold of tomorrow.
Mark
MrHanky
Checked with my local Mazda dealer and he can supply the pins (hopefully correct ones).  Should be here in a few days, so will see then.  Really need these to be correct, or I doubt I will get the new pads on for Mallory :(
Thanks for the help
Mark
