Factory BOV Sound?
Started by Macca-RX7, April 03, 2010, 01:26:31 PM
Macca-RX7
Hi, i came across a video on youtube of a guy who has done something to make his factory bov make a sound? Anyone else heard of this / done this? Im interested in doing it :)
http://www.youtube.com/watch?v=IwKVEPGvz0Q
G@NDY
Yes it simples. Just unplug it from the airbox :)
Macca-RX7
I\'ll need to blank off the bit on air box then wouldn\'t I?
G@NDY
Ive got a 50/50 here as its been a while since I had an FD, but I think its the one that ive circled, the other is a charge relief valve. HTH
G@NDY
Yep, ive seen people use spark plugs, batteries anything to just block the hole up matey.
Macca-RX7
Came across a diagram, the one you circled is the charge relief.
The one at the front is the air bypass valve
neil_jdmr
Yep the black one at the front is the air-bypass(bov) its the furthest forward one, If you vent it to air then it will give the whooosh but you also gain an annoying off boost whistle.
Macca-RX7
#7
Ok done it this morning. There is air passing through the vented bit of the valve when on idle/no boost. Is this bad for the car with regard to air leaks / MAF sensors / fueling?
G@NDY
Lol, 50/50 and got the wrong one. No its fine like that, I ran my car like that for years matey.
