Hard start FD when hot
Started by joe 93, February 23, 2010, 11:27:23 PM
joe 93
Can any tell me if this is signs of needing a rebuild if the car is hard start when it\'s hot.Thanks in advance.
brundish24
maybe mate im not sure but could me water seal failure but im no expert.
rx-dave
That\'s usually a bad sign :mad:.  It\'s always worth servicing the car again before you panick too much......
russellparkerx
Time to take it in for a check over by the sound.  Are you losing water?
Hi Joe,
Try and get a compression check carried out as this will tell you the health of your engine and then you can go from there,
