does the Defi tachometer meter work on rotarys??
Started by rotaryheaven, February 10, 2010, 12:27:58 AM
rotaryheaven
As above really, i\'ve just brought defi bf water and boost gauges and I wanted to add a tachometer meter and get rid of the dash clocks all together :)
lee mills
rotaryheaven
Sweet, what settings have you got the switches set at on the side of the controller?
L18M
Quote from: rotaryheaven;671412Sweet, what settings have you got the switches set at on the side of the controller?
this might help
http://www.defi-shop.com/product/images/dlink-manual06064e.pdf
page 34.
assuming urs is twin rotor then pins 1,2,4 up position. pin 3 down position. :)
