Ignition coils
Started by jackaleks, January 04, 2010, 09:54:47 AM
jackaleks
what are the options for replacing the old ignition coils? i\'m not going to be going for much power, maybe 300fwhp on stock twins, i just want reliability. :)
how much are new Mazda ones? or can you get direct replacements from someone like MSD?
thanks,
dwarfslapper
well worth doing had mine done at REworx i think they were bosch items might be worth giving them a buz
Paul
For sale:Thumbsup! http://www.mazdarotaryclub.com/forums/showthread.php?t=34314
High maintenance,but aren\'t all beautiful girls:InLove
jackaleks
Quote from: dwarfslapper;663272well worth doing had mine done at REworx i think they were bosch items might be worth giving them a buz
yeah, after a bit of digging it looks like this is easiest over stock.
a lot of people on RX7Club talk about hooking up an MSD 5/6 and some Blasters. When you do this do you use a seperate ignition control for each coil? so you\'d need four controls and four coils.
jackaleks
Quote from: jackaleks;663412yeah, after a bit of digging it looks like this is easiest over stock.
thinking about this, the leading plugs share a spark so you\'d only need one controller, right? so the circuit would be something like:
ECU signal + 12v power > MSD 6 > coil 1 > coil 2
...............................................plug 1...plug 2
then, are the coils better in series (like above, if my crap diagram makes sense :2Rolleyes) or in parallel? or am i just talking ....? :D
raceralexuk
I use GM LS2 coils (off the Corvette) on my \'7. I use an alternative ECU but I have heard of RX-8 guys using them as a direct replacement for the Denso coils.
