Will I need a new map?
Started by jay, May 04, 2004, 09:32:20 PM
jay
Recently had my FD mapped by Geff 241 atw.
Mods are:-
Blitz Front Mount
Apexi N1 zorst
De-cat
Hks Induction
Power Fc
Apexi RSM
Well I\'m goin formore power so I\'m fittin a HKS front pipe and mid pipe to start with and my question is how much more power will this give me roughly and will i need to get it mapped again?
 Cheers Jay...:wave
FEED O PHILE.......REworx Streetported runnin GT35r and covered in carbon+ Volk GTC\'s
Daily.........MK2 golf 2.9 supercharged runnin 290bhp covered in Trophies:Thumbs-up
20B_boy
20-30hp?
Yeah, quick tinker with the map I\'d say; mid pipe makes a big difference to exhaust...
R.
kevint
Hope the front pipe does the job ;)
Kevin
jay
Nice one Rich.....
 Might as well pickyour brains....... Goin to go with some bigger injectors and fuel pump soon. Any ideas what size make and cost my knowlegable friend.....
 Cheers Jay...:wave
20B_boy
Long term goals? spec your fuel system for whatever you MIGHT end up doing... Do you intend staying with the twin turbos? what boost do you intend to run - and so on...
R.
jay
Goin to stick with the twins as i dont really want to go too mad.:rolleyes:
not really lookin to run massive boost .8 at the mo using 81% inj duty so I just asumed bigger inj were a good idea. basically lookin for reasonably reliable, reasonable power nothing too extreme.I know if i go down the single route i will chuck loads of cash at it and if i do have to sell it on it may be harder.
 Cheers Jay...:wave
20B_boy
In that case I\'d just get a rising rate regulator, may be a cheap bosch pump like a 404 if you really want. Stick the exhaust bits on and see how wanting you are on the fuel front. With a slightly higher rail pressure you\'ll probably find your ok on inj duty I\'d guess...
R.
GaryS
I went for a Bosch 404 in tank pump and 1200 secondaries and now with an Apexi GT intercooler run at about 80% inj duty at WOT.
Fuelling will make a surprising difference as well, though I\'m now at the point where I\'m possibly looking at higher temperature spark plugs.  Think I\'ll need a spark boost pack of some sort to try and counter the cold/hot start/flooding problems some people get with them.
20B_boy
Depends on your boost Jay, if yer going to run say 10psi then I think injectors will be over kill. 1 bar on the other hand, swapping out the stock 850 secondaries for 1200s (which fit the stock rail) would be the way to go. How much booooost do u want mate? :)
R.
jay
.1 Bar would be plenty i think Rich. I dont want to go too mad:rolleyes:  1200 secondries fit on a standard rail......hmmm....... sounds good. What elsewould i need apart from the pump and roughly how much mate?
 Cheers Jay....:wave
