twin or single turbo
Started by Jas, September 24, 2009, 12:02:55 AM
Ada7
You could try finding a set of 99 spec twins as these are slightly better than the earlier ones and can give a little more power.
Might no of some for sale ;)
Adam
I AM HERCULESIAN
Jas
rotechniks have offered to port the turbos as im told it will speed the spool?
An obsession was just the start.
suba
I\'m sure that they would flow a bit better, and if you have the turbo pack off the car then it\'s worth doing, otherwise I think it would be a lot of work for a very small gain.
Single Turbo time!
Jas
yer im having the engine ported and polished so i think i should have it done all at the same time :)
