Are these solenoid plugs the right way round?
Started by nuki, September 27, 2009, 12:46:47 PM
nuki
Bascially ive run into an issue with these solenoids and cant remember which way round the plugs go and if they would make a difference if plugged in the wrong way around...
Can anyone confirm this is the correct way they should be plugged in with the white Dot on the plug connector to the right hand solenoid? If so what would happen if the plug was on the wrong solenoid? thank you.
philiwily
neil_jdmr
Looks the right way round mate, If those plugs are wrong then you get overboost on the primary and and 0.5bar on the secondary
nuki
yes that was my problemmmmm when i went for a drive yesterday! changed the plugs around and now the problem is gone :D thank you.
