Whats the trick to replacing belts? (FC)
Started by mukumu kurubushi, October 22, 2009, 11:22:18 PM
mukumu kurubushi
Hi guys
Just wondering if anyone knows of a knack for getting the a/c and p/s belts on a bit easier??
I\'m currently in the middle of disconnecting my air pump & going dual belt alt pulley. got the new pulley on with both alt belts, but im failing with the others. They\'re a proper pain to get on!
Haynes manual says the p/s component is apparently adjustable (havent tried that yet) but the a/c isnt adjustable. Even trying hot water,  even cranking the 22mm nut on the alternator with a  breaker bar, there\'s not enough slack & doesnt seem to want to move.
Any suggestions very much appreciated!
For the power steering one, there is an idler pulley - unlock the adjuster on the side of the bracket, and then wind it right down - belt will go on and off really easy.
As for the air con - don\'t know as I don\'t have it - but imagine it must have a similar setup
mukumu kurubushi
Cool, thanks Prof. Will give that a go on the power steering.
I have a feeling the air con just needs brute force i guess :(.
L18M
could try this??
http://www.youtube.com/v/BQhfcdQf1QA&hl=en&fs=1&">http://www.youtube.com/v/BQhfcdQf1QA&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344">
grinder
The tightest man on earth
:Giggle
h20490
Holy crap!
I thought it was a joke when it was half buffered and I saw the screw driver!
Anyone want to do mine?
Ash
mukumu kurubushi
Just had a look in my bay, i can see the adjuster bolt on the p/s bracket. There\'s 2 actually, another one for the a/c.
Duh! Was right in front of me all along! :Hammer Thanks Prof. I\'ll give this a go tomorrow i think, tonight is pub + forza 3!
:guinness:3gears-rh
