FD master cylinder res. removal?
Started by m1tch, September 16, 2009, 04:51:14 PM
Hi guys, just aquired an FD master cylinder that I can apparently use on my turbo II FC, the res. needs a clean out, I have unscrewed the screw underneath is it just the case that the 2 rubber things are holding it in and I just need to pull it apart?
Secondly, what should I wash it out with? I know there is that sensor in there that detects low level.
Would it be easier to just use some brake fluid in the tank whilst its all attached to get all the dirt out of it?
