What RPM do you need to acheive to remain on the second turbo
Started by pigeon, September 02, 2009, 05:47:42 PM
pigeon
As the title goes really. After the transition at 4500rpm on WOT, what do the revs need to build to as a minimum, so you can shift, and remain on the second turbo.
Cheers Adam
Timmy
Jono FD3
The second tubby drops offline when the RPM is lower than 3k IIRC, so if you change at 6 & the RPM stays above 3k your twins are in full swing!!
pigeon
Quote from: Jono FD3;639166The second tubby drops offline when the RPM is lower than 3k IIRC, so if you change at 6 & the RPM stays above 3k your twins are in full swing!!
Cheers dude :Thumbs-up
Adam
