few problems to solve..
Started by LRP, August 05, 2009, 08:37:20 PM
LRP
Not been on here for a while since selling my pride and joy to buy a house:2Confused
Been asked by a friend to have a look at his k-plate rx7, recentally had a rebuild , was running fine till all of a sudden the idle started to be very irratic , like a bridge port , cleaned out throttle body and set the air screw correctly , and a fresh set of plugs , ow yeh its be converted to non-sequencial!!!!!!
Seems to have sorted the idle but its also down on power if the blip thr throttle its cuts like fuel cut?????? any ideas , its also lost all electrics to the instrument panel , ive checked the plug up behing ecu and is plugged in checked all fuses ok , removed the turbo timer incase that was causing a break ?????any help or ideas please chaps..:Thumbs-up
complete wankel :god
tyson23
sounds like your main earth to engine/body is crap check clean it up
col_fd3s
as for instruments, i lost mine recently and it turned out to the the TNS relay in the bank by the bonnet release. so have a fiddle with that.
col
