Wheels
Started by robbierx7, July 08, 2009, 03:07:36 PM
robbierx7
hey guys, im ordering a new set of wheels and just want to make sure that 9.5 inch is ok on the front of my fd? it has chargespeed wide arches on the front which i think are 20mm wider than standard.
just wanna make sure there are no problems on full lock or anything
thanks
robbierx7
by the way i think the tyres that come with the wheels are 265 wide if that helps.
SiH
What offset are the wheels? :)
robbierx7
the wheels are a 20 offset.:driving
skybusr34
think you`ll struggle with 20et. do they do 8.5 for front with 235 tyre?
robbierx7
they do 8.5 but there a 38 offset and im not a bit fan of havin spacers on?
wat yous think?
the rears are 9.5 on a 10 offset but iv 50mm arches so will be ok.
skybusr34
Quote from: robbierx7;624471they do 8.5 but there a 38 offset and im not a bit fan of havin spacers on?
wat yous think?
think you`ll be ok with the rears JUST!!!!. but dont think the fronts will work mate.
spacers are ok just get the quality ones that you bolt to the hub then you bolt your alloy to spacer.   not the poop packer type that supply long bolts.
if you got 20mm spacer i think it would be ok
SiH
9.5 et20 will tuck the tread with a 225 :)
There\'s NOTHING wrong with spacers with longer studs. H&R ones are TUV approved - they can\'t be that bad ;) I\'ve run them on various cars for about 30k with no issues - road and track.
Rears will be fine if you have done the rear arches properly - I.e. cut out the original lip :)
You may have issues with 265\'s on the front though.
skybusr34
Quote from: SiH;6244899.5 et20 will tuck the tread with a 225 :)
i stand corrected on the spacers. .
robbierx7
Quote from: skybusr34;624485if you got 20mm spacer i think it would be ok
the wheels i have on are 38 offset, and the arches are now 20 mm wider.
if i put 20 mm spacers on, wouldnt that be more or less the same as getting 20 offset wheels??
also what about stretching maybe a 225/235 tyre on. would that give me the clearance i need???
thanks for the help lads.
SiH
Yep, and yep  :)
I run 225\'s on a 9.5j et20 on the front on stock bodywork :)
robbierx7
Quote from: SiH;624667Yep, and yep :)
id say there tight to the arch!!
any pictures of them??:cheers
SiH
They are tight, but I like a bit of a tuck :)
No piccies, sorry, may have at the end of next week, but not before then :(
