What would cause....
Started by trotter, June 17, 2009, 11:04:33 AM
trotter
...the \'Heat\' light to come on and stay on for a few seconds??
I know that it\'s not knock as my values are OK, nothing has changed to cause injector duty problems (causing it to flash)
Did it originally come on and stay on to indicate a hot cat?
Work hard, play hard house :D
Aubec
Yes, that was what it was for.  I believe there is a temperature sensor by the tunnel on the passenger floor?
Aubec
1995 UK Silver FD
AndyGen3
Sensor might be on its way out . .
gsb876
faulty sensor chap, on my satin rx it was on all the time, even when water temp was like 10oC :spank
trotter
no worries, cat isn\'t on anymore anyway so guess it\'s nothing to worry about!
cheers lads :D
HaywardRotary
Maxing out the injectors will also see the light come on when using a power FC ecu.
Regards
Carl
Single turbo conversions.
S
trotter
I thought that maxing injectors causes it to flash?
My light comes on solidly for a few seconds. And it\'s usually whilst stationary or under very light load??
