loud squeeking
Started by thomas_mk6, June 02, 2009, 12:34:27 AM
thomas_mk6
hey guys this is my forst post s an rx7 owner, not had the car long its a 1994 type r and it had mazdaspeed coilovers, but there is a very loud/annoying squeek coming from the rear when driving, it also makes the same sound if you press down on the rear of the car, im guessing its the rear shocks but maybe this is a common fault? anyone have any experience with mazdaspeed coilovers?
rx7boy
Ive got the same mazdaspeed squeak on the rear was told that its normal but not sure if that entirely true, Need to get my front ones rebuilt so if you find anywhere to get them done let me know thanks
DM-Motorsport.co.uk
gmogle
Just check it isnt the boot mechanism mate, mine made the most annoying squeek until I sorted it. Try pushing the car down with the boot open.
Bobbit
I had the rear boot squeek, to fix it i move the catch down a few mill and also put plastic washers under the rubber stops in the back.
:Laugh LOL
thomas_mk6
ill try the boot adjustment but the reason i thought it was the suspension is because it does it when i push down on the rear of the car, but ill take the wheel off tomorrow and have a good look around
