Boost drop
Started by rx7ben, May 03, 2009, 08:17:44 AM
rx7ben
Hey guys im hopeing some of you may be able to help me out with a little issue im having. When im hard on the gas up high in the revs im getting a slight drop in boost on my stock twins and i can feel the car hesitating abit. Its like  the boost is going up and down by a few psi. Now this only happens up high in the revs low down its fine.
Anybody have any idea what this could be.
On an FD its usually the boost solinoid or a slightly leaking hose, search on the forum under FD boost leak, you should have some pointers from there :)
rx7ben
Thanks ive had a look and this seems to be a common problem. If i wanted to change all of these where would i get the parts from.
