Is this normall
Started by rx7ben, June 23, 2009, 04:14:30 PM
rx7ben
Hi guys just wanted to check this out.
Everytime i fill the coolant up to the top and take a drive im allways loosing abit of water. Its not alot at all but it doesnt stay full. Is this ok ? could it be something really silly like its leaking threw the cap.
Thanks, sorry if its a silly question but i allways like to make shaw :yes
peterwolds
dont worry doesnt need filling right to the top will dump a bit out,so long as you can still see it in the neck no problem
:Typing Pete
rx7ben
Cheers mate thought i better check :3Confused
NurburgRob
I\'ve got a similar problem myself sir, unfortunately it could be one of many things.  Search for coolant issues and a few threads will explain how to check what could be causing it.
Do you have a lot of coolant in the plastic container behind the drivers side headlight?  I have so I\'mm thinking its not loosing coolant but there is an air lock or blockage that is stopping the coolant returning to the main system.
rx7ben
Quote from: NurburgRob;619467I\'ve got a similar problem myself sir, unfortunately it could be one of many things. Search for coolant issues and a few threads will explain how to check what could be causing it.
Yep theres plenty of coolant in the plastice bit so i dont think its leaking.
