13b Turbo II
Started by yellowmazdaman, April 13, 2004, 05:25:08 AM
yellowmazdaman
Ok I have a quick question I just picked up a 13b Turbo II for free. But I have a 1982 RX-7 GSL. Can it fit,  if so how much work?? THANKS GUYS&GALS.:wave
richrx
easy answer yes. its a popular conversion in the states. if you check their forums there will be info on it there.
rik
antnicuk
i have an elford turbo 1985 1st gen with a turbo II engine and gearbox. The main problem was the turbo fouled the steering so i had a rack and pinion fitted which was major grief due to the set up of the 1st gen steering. This was 5 years ago now so there maybe some more people who could sort it.  Not sure if you could sort the problem a different way with a single turbo manifold from a 3rd gen. They seem to move the turbo forward, there wernt any about when i did it hence the steering was changed also the steering on the 1st gens is very poor.
regards
tony
