sound deadening
Started by lee mills, March 21, 2009, 07:55:01 PM
lee mills
Started stripping the car today removed pretty much everything except for dash. my question is is there any easy way to remove the sound deadening or is it just a question of shed loads of elbow grease. any help appreciated
Lee
Adam fc
i recently stripped my back seats out and got carried away and decided to rip the sound deadening out,i just used a heat gun and a scraper and it feeled away like hot glue.
lee mills
should be doing the rest tommorow so i will give this a try
Lee
jon_smith
I have been doing mine today. I just used a hammer and flathead screwdriver, then a wire brush in a drill to clean it all up.
Jon
grinder
i just used a hammer and an old chisel - just dont hit it too hard - you might end up finding rust that you didnt expect ;)
The tightest man on earth
:Giggle
lee mills
thats what ive used so far today but it leaves that horrible glue residue. luckily being a carpenter i know how to use a chisel:Laugh
lee mills
finished removing sound deadening from the back today with a chisel and wire wheel then give it a coat of primer. Just the front to go:2Rolleyes
jon_smith
Not to put a downer on your work but the front half of the car was sooooo much harder to do its unreal. It has taken me a full day to get it all out/cleaned up.  Starting to paint it now though :Giggle
jon
Ricco_04
I found once you chipped it away its good to use a solvent and rag to wipe the residue away.  I tried white spirit and it just melted what was left and cleaned up a treat :)
Ste00
I got bored using thinners to get the glue off so broke out the angle grinder and a wire wheel :D works loads better done the whole front in less than a day
lee mills
found the front a lot easier than the back. have done most of it but rain stopped play:Giggle only took about an hour
