filling back up with coolant
Started by carlos, April 12, 2004, 08:36:21 PM
carlos
i will be replacing the waterpump and gasket 2morrow, n e pointers??? also which is the best way to refill the coolant? plz dont stay just pour it in... lol.:D
skybusr34
remove the pressure cap.   and fill at the filling point nearest water pump.  when coolant fills system it will rise in the plastic bottle ( don`t remember name- where pressure cap goes).  put pressure cap back on and continue to fill untill top filling point is full.   run engine untill its upto temp. then turn off untill  coolant is cool.   do process over untill no more coolant is required.......... i was told this other day. worked for me.    good luck with the task
carlos
thanx, will it harm my engine doing this?
