Light problem
Started by chrisyerkes, January 24, 2009, 08:03:12 PM
chrisyerkes
I just bought a FD RHD and the headlights won\'t come on none of the instrument lights come on. The turn signals work fine and the interior light on the headliner comes on but thats it. I thought it might be a fuse but I have no clue where to look. I found a set of fuses under the driver side. Is there a relay that I might have to replace or coud it be something else.
logicalChimp
There is a second set of fuses in the engine bay, on the passenger side behind the main headlights (if they haven\'t been moved for engine bay modifications).  I\'m not 100% certain, but I think the main headlight fuse is in there...
Also, in the cabin, there is a little scroll-wheel thingie to the right of the air-con switches (or perhaps a little lower) - this is used to dim the dashboard lights.  I\'ve brushed it in the past, and ended up switching the dashboard lights off - took me ages to realise ;)
hth
trotter
yeah, it\'s attached to the right of the battery tray and is connected directly to the positive terminal. The main electrics fuse (120A) is in there, along with the headlights and pop-up motor fuses amongst others.
 - logicalchimp....D\'OHHHHHHHHHHH!! :spank
Work hard, play hard house :D
