Just got it home
Started by A R, February 24, 2009, 09:38:23 PM
A R
Well thru to the description the car need a lot of little and medium things done. I am reading the Haynes manual but it makes little sense.
The steerings is "interesting" to say the least. At first I was a bit like James May when he was driving the Countach and said that one should not meet childhood heroes!
Well after 274 miles we bonded well. :3gears-lh
Here is the preliminary list of priorities:
Inspect everything and replace/repair as much as I can afford!
Cheers,
AR
rx7boy
Good to hear you bonded it will only grow stronger with time, or until the money runs out ! :P
Got any pictures ??
DM-Motorsport.co.uk
A R
I would have taken a few but it wa stoo dark, I will take some tomorrow, after I wash it a little.
Does anyone know where the temperature should read? Mine was reading about a quarter of way up???
Cheers,
AR
Baz-7
mpk490p
Quote from: A R;587122I would have taken a few but it wa stoo dark, I will take some tomorrow, after I wash it a little.
Cheers,
AR
welcome,
the temp looks fine especially with the cooler weather at the mo, the gauges are more of a general idea, i have aftermarket oil, water and exhaust to help keep a eye on things
A R
I am thinking of going with separate gauges as you mentioned. I was thinking of an A/F gauge as well???
If feels strange having a car with a caburator and distributor as most of my other cars have being fuel injected or diesel.
I com pletely forgot that cars had chokes!
A R
Quote from: Baz-7;587136Good luck with the car! :D
Thanks, :) I am hoping to get all the service bits soon.
Cheers,
AR
David Nock (RIP)
Cheers,
AR
Ours runs just below the half way point, never above half way.
Sadly Missed
A R
I will check to make sure all sensors are where they should be.
Cheers,
AR
