ecu???
Started by cush, January 02, 2009, 01:46:00 PM
cush
i have had my car decatted for ages now and only just found out that i should get it remaped what do i need to get for someone to the map it accordingly?
davehg
you will need an ecu like an apexi for example. the standard ECU is not re mappable.
Bobbit
depends on which ecu your running bud, if it\'s a standard you\'ll need a re-mapable one, so expect to pay £400 for the ecu then mapping costs on top, but if you get it done you\'ll hopefully get a more powerful machine, so it is worth doing.
If you\'ve got a re-mapable one already you\'ll just need a mapping session circa £200
:Laugh LOL
Tomcat
damm...i didnt realise by just putting a decat pipe in you will need a re-map?
looks like i might have to buy a new ecu :(
