how heavy is the fc range...
Started by rxv8, December 23, 2008, 03:28:40 PM
TiddlesRX7
Yeah the air pump is to do with the emissions if you\'ve got a stock intake and exhaust. It pumps air into the stock exhaust before the cat to help with the emissions. I\'m gonna remove mine this year. its one of my many goals im gonna hit that i\'ve never got round to doing.
You don\'t know how long that took to wright. I\'m so drunk right now. Merry Christmas!
Jimi_Hendrix
Quote from: adereed;568421You don\'t know how long that took to wright. I\'m so drunk right now. Merry Christmas!
Ha ha! Thats the way things ought to be in the festive season! Full of.... ahem, christmas cheer! Lol! Have a gud un guys!
Sorry been away a while :) -  The \'Vac Rack\' is all the metal vac pipes that sit under the manifold.  Once you remove the emissions stuff, virtually all of it is redundant and can be removed.  At the most basic, you need only the fuel lines (can run seperate braided ones, so the stock piping can go), a vacuum line to the fuel pressure regulator, and the oil feed to the turbo.  The rest of the piping and the solenoids can be removed - they weigh in at about 2-3 Kg\'s - not much weight but it simplifies things to get rid of them.
Quote from: Prof;570393Sorry been away a while :) -  The \'Vac Rack\' is all the metal vac pipes that sit under the manifold.  Once you remove the emissions stuff, virtually all of it is redundant and can be removed.  At the most basic, you need only the fuel lines (can run seperate braided ones, so the stock piping can go), a vacuum line to the fuel pressure regulator, and the oil feed to the turbo.  The rest of the piping and the solenoids can be removed - they weigh in at about 2-3 Kg\'s - not much weight but it simplifies things to get rid of them.
I have seen whats left of Prof\'s vac rack....its been condensed to about 1 pipe lol :D
