AFR Ratio
Started by ash, December 11, 2008, 09:54:24 AM
ash
Can someone please? Just put my mind at rest on my AFR gauge reading. I have just bought a new RX7 with loads of gauges including a GReddy AFR guage. When cruising its reads 8.0, and when lifting off it reads the other endof the scale 16.0 i think.
So is 8.0 Rich i.e. 8 Air : 1 Fuel
and
16.0 i.e. 16 Air : 1 Fuel
So is this ok?
P.s - its a single turbo.
Also heard that these non - wideband gauges are useless!! :Giggle
BlitzBoy
ahh its a narrowband, next to useless, just tells if you are running on Rich scale or Lean, just looks pretty
Rotorstock winner 08,09
New Project
"el fénix" RX2 by Mark & Mark
hairyhoover
dont narrow band whizz back and forth when cruising and idling?
ash
Yeah it really is a bit distracting when your not sure what they should be doing. So should i be worried about the readings or just be happy with my portable Christmas Tree?
BlitzBoy
Just be happy with your new Christmas tree lol
New Project
ash
Nice One! Cheers Blitz!
or buy an Innovate LC-1 Wideband controller and use one of it\'s analog outputs to drive the \'useless\' gauge - and make it a little more useful. :Thumbs-up
ash
Just had a quick look at the LC-1 controller..hmm bit expensive are\'nt they!
hairyhoover
wideband arnt cheap but worth the cash! although it does make you a bit paranoid!
Will66
Am I right in saying that 12:1 is pretty much the ideal AFR?
"Eat it with a chopstick!"
BlitzBoy
depends on boost pressure, low boost up to 12psi 12:1 is fine, the higher the boost you go the richer you should be to aid chargecooling and stop det.
On NA probably 13:1 at WOT but tuners have there own numbers they use for best power and the type of petrol being used
New Project
Will66
Aha, interesting!  I think I can get my CampII to show AFR, I might have a look at what mine does!
BlitzBoy
yep you will need to get a Bosch (or similar) wideband sensor fitted before the CAT pipe to get a true reading then hook it up to your camp unit
New Project
nikp
Aren\'t bosch the only suppliers of the sensor? I am not aware of anyone else making them - but i may be wrong!
You can either spend a bit more cash on a wideband sensor and get a good reading, or not and the engine run lean and cause you to need a rebuild lol I know what I would wanna choose :D
