building a single rotor....
Started by pigeon, November 08, 2008, 10:31:19 PM
pigeon
so basically once i have built my engine for my car im gonna have two spare engines. was thinking the other day that it carnt be all that hard to build a single rotor. anyone ever done it or heard anything about it. i figure the hardest part is gonna be machining the e-shaft. just gonna do it for ****s and giggles but still want to do it properly.
any info or input would be great
cheers adam
adib
be a bit slow so may be smart cars will start putting it in there cars :Laugh
Jimi_Hendrix
G@NDY
Heard it being done for go-karts, and other similar applications. Never cars tho !
Carl
Drainage of oil back into the sump is the area you need to look at most as the oil on two rotors drains through the center plate.
Then the rotating assembly needs balancing.
Regards
Carl
Dan Norton
Yea....stick it on a go kart chassis!!!!
That would be awesome.....you could get 100bhp with one rotor couldnt you?
Turned into the worst part of my life....my precious fd3 has gone, but never forgotten....roll on a new life!!!!
dthebuk
surely you\'d be need a PP for that? which would me even worse low down torque.
Also the single rotor go carts have single engines i believe and kick out around 50 hp
http://www.youtube.com/v/tKayagHUCw8&hl=en&fs=1">http://www.youtube.com/v/tKayagHUCw8&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344">
:burnout
Dan Norton
skybusr34
they are only 50cc rotary engines and cost 2500 quid.
DMDRIFTING
I want one of those waaaaaaaaaahooooo
