Urgent help needed
Started by Cooch, March 02, 2009, 01:17:24 PM
Cooch
Cooch
p.s doesnt need housings or rotors.
Cooch
leon
First id take it appart to see exactly what you need. (As you may find some unexpected suprises.) Also depends on what you got a lot of the items are \'external\' to the engines block you have listed.
Basic compression things would be:
Apex Seals x 6
Corner seals with plugs x 12
Corner seal springs x12
Short/Long apex seal springs x 6
Side Seals x 12
Side Seal Springs x 12
Oil seal rings
Oil seal springs
Inner/outer water seals then anything else such as rear oil seal and front/rear oil seal.
Can get quite a large list!
I woof in your general direction.
Cooch
Yeah i just copied and pasted a list i was e-mailed. What youve said above sounds right. Might need bearings too. Thanks Leon
Jim_rx7
Like already said, take it apart and see what you need.
I rebuilt mine with a full seal kit, corner seal springs and side seal springs. Everything else was well within tolerance. It was actually rebuilt 3K miles ago previously.
