Hello....
Started by mark-ashley, August 21, 2008, 12:56:14 PM
Nik da Greek
Here you go...
[ATTACH]40937[/ATTACH]
The one circled in red is the one that needs the restrictor in it. I made mine from a hose joiner of the right diameter for the pipe, with a bit of silicone vacuum hose Sikaflex\'ed into it so the engine couldn\'t suck it in lol
mark-ashley
Well, since i took the pipe off the airbox the mooing has stopped so i can only assume that where i have put the BOV on, it\'s dumping into the air box...
I\'m 99.9% sure that if i put the CRV valve back in place and remove the Air bypass valve and replace with the BOV i shoud be all good, however, if the mooing continues i\'ll be following your anti mooing suggestions !
1993 FD3S - Street port, Decat, Apexi FC, Apexi Induction - Engine rebuilt and installed by Hayward Rotary, too fast for the mean streets of Croydon !
