Aircon seized.... bit of advise required pls!
Started by Habanos, August 29, 2008, 10:38:33 PM
Habanos
To cut a long story short, my ircon appears to have "seized up" Loads of white smoke and buring rubber smell coming from behind the battery ( have already posted this part )
Removed the P/S and A/C belt, checked the pulley\'s and the A/C pulley is locked solid. Got a belt to bypass the aircon pulley and all is good again.
I like to use the in dash A/C button to turn on the fans to cool things down a bit ( running stock ECU ) which still works. Speaking to a guy from Thurmaston ( sorry forgot your name) at Rotorstock and he suggested "disconnecting" the A/C unit. White clip underneath, accessed from underneath the car.
Anyway, can I leave things as they are and continue to use the internal a/c button without causing a  problem? Not really looking to remove the A/C condenser etc so just making sure I\'m not causing myself a problem. Or do I need to disconect the A/C unit. Read that removing the fuse will stop the fans working.
Any help would be appreciated.
JB
Brett
Sounds like you\'ve probably had a leak in the system - iirc aircon systems contain a % of lubricant along with the gas.
Lots of people have got rid of their a/c systems so you should be able to pick up a servicable pump on the cheap.
:wave
Brap Brap Brap Brap
SiH
As above - sounds like a leak and then seizure :(
I\'ve got all teh AC gubbins if you need it, and I\'m jsut down the road in Kenilworth, below Coventry :)
Habanos
Thanks for the info, and offer of parts SIH.
I think I\'ll go down the removal route, the A/C has never worked since I\'ve had the car ( 2 years ), not in the sense of cooling anyway. Not my daily driver, so for the times that I do drive it, It\'s never been a problem for me. If a little sweaty on the odd ocaision in the summer!
I\'ve only ever used it to put the fans on to lower the water temps when I see the WT gauge rising above 90is ( in traffic etc ) Stock ECU has a fault ( according to Pip @ WGT ) so got another one from Matt on here, just need to get round to fitting it, hence the use of the a/c fan button at the mo.
I read on the forum you can remove all the bits and keep the Rad fans for cooling. So I think I\'ll go down this route. Just checking that I\'m OK driving the car and using the a/c switch at the moment until I get round to removing the main bits ( condensor etc )
JB
Steve-Q
#4
Quote from: Habanos;529113Thanks for the info, and offer of parts SIH.
JB
Hi Matey,
Ive just had the air con system taken off mine to fit the front mount in, the system on mine work 100%. Give Steve, Dwayne or Colin a Ring at LINDOPMOTORSPORT and im sure we can do you a deal on any bits you need. numbers 07970 776634
or give us a call and we will remove the air con for you, can even collect and deliver you car if need be!!
cheers
Steve Q
SiH
All you need to remove it is a belt - it\'s from a Daewoo or something - can\'t remember which :)
Might be a 1.7 deisel Ibiza without aircon or similar, my memory is hazy! If you need a hand let me know and pop over, i\'ll happily lend a hand :)
