1976 Mazda 1300
Started by 2002Gimp, July 03, 2008, 02:23:06 PM
2002Gimp
Thought i\'d post up some pics of my Mazda, bought from KeithB off this forum.
This is his selling post
http://mazdarotaryclub.com/forums/showthread.php?t=45608&highlight=1300
I\'ve done a few bits so far
I whipped the Drivers front wing off and i found something to make me cry a little!
Ah well, best get making some plates up.  I use vinyl sticker sheet to make the templates, its got quite a thick backing on and once its cut you can stick it on the steel to make it easy to make the panel
First bit welded in, yup i forgot to turn the gas on for the bottom weld, you can see it gets better for the vertical one
Few more plates and several hours later
One inner wing repaired, sprayed with Zinc Primer, then a thick coat of hammerite
Next was to tackle the job i actually wanted to do in the first place
Cut all the crap out and made up my plates
The lightest skim of wag (i\'m not trying to hide owt)
Rubbed down
Next was to lay some colour down
My prefered weapon of choice is my Sata NR95
Layed on a nice thick coat of filler primer
Flatted it back then gave it a shot of white basecoat as i\'m waiting on my paint to arrive
Done
You can see i\'ve binned the front repeater as well, makes it cleaner looking!
Same to do on the other side now, then the doors to tackle   :-[
Next was to sort out her flacid backend with some new poly bushes, also pulled off the front wing i repaired and threw on a \'glass one from S&D, very impressed with the quality.
Looked at the rear arch as well, had this small hole in there and also the lower part of the rear quarter had rotted away.
Normally i\'d cut out a square of metal and well in a repair, but on stripping the rust back the metal was still thick and in good condition, so i decided to just fill the hole.
You can see my lower quarter repair here, she\'s loads quieter now on the roads as this panel has filled a hole that went straight into the boot, so it was scooping up air and throwing it around the inside of the car  :shock:
All primed up waiting for paint
Oh, pulled all the carpets up as well, this thing is absolutly immaculate floorpan wise.  All the floors are perfect, the boot is stunning, under the bonnet is great, i\'ve been under her and she\'s been waxoiled from new so its all good down there.  Shame the wings and doors let her down, but once done, she\'ll be proper solid!
My Blue paint finally arrived (you try getting hold of 2k these days) so I gave the new wing a quick shoot over
Decided to tackle the drivers door next as its the worst.
Took a look with it in situe, but decided if def needed to come off
Once off the fun began
This is what I was up against
Cut it out, no mercy
After a few hours welding and grinding
Next up a skim of wag.  Its not surprising a thin sheet held only as the edges warped during welding, hence the filler half way up the doors, still, its only thin...
Primed and back on car awainting paint
Its a shame the front doors and front wings are as bad as they are, underneath is rock solid and mechanically she\'s sound...
A Little more work!
Rushing this bit through slightly as i dont want her covered in Primer for the Retro Cars show this weekend, so i\'ll no doubt be stripping it back at a later date!
Laid some colour down on the rear arch, first attempt at blending in paintwork as i didn\'t want to have to paint the whole rear quarter and its worked out pretty well, just needs a good going over with the G3 in a few days.
I need to get the hammer and dollies out to sort out the distortion on the repaired door skin (due to welding heat), but i have not time, so i\'ll just blow over the door for the show, hopefully it wont be that noticable?
On a mechanical note, she developed an annoying tap in the engine bay the other night.  I thought it was the waterpump so bought on off ebay, but on closer inspection the fan belt was fecked causing the noise.
No problem, just open the boot and delve into the box of genuine spares
Fitted, working - Done!
Oh, this is my daily driver as well :yes
Welcome to MRC and well done with the excellent resoration work you have carried out that would put some body shops to shame :Thumbsup!
SmbFD3S
Excellent work there mate :D it\'s nice to see someone doing all their own work and not just shipping it off to a bodyshop to sort out :D
Oh yeah and welcome to the club :) And local too.....:)
\'92 UK RX7 FD
\'86 Honda CRM250R stroker
\'11 BMW 320d ED
grinder
that has to be one of the best first posts i have ever read
and welcome to MRC
Stu
The tightest man on earth
:Giggle
shaunwil
Wow, wish I was that brave with the 1st gen ! Awesome work :D
Shaun
robedwards99
Feckin\' awesome. Much respect mate. :)
My love of old school is growing... I just wish I had the skills and garage and tools to be brave enough to buy one of the old jap bargains there is to be had. :)
Brett
Looking better every time I see it :yes
Keep up the good work :wave
Brap Brap Brap Brap
2002Gimp
Last bit of work for the show.
Finished the front door.  When I say finished I actually mean, I blew over the door bottom, so if anyone does take a photo or glance at her she\'ll look alright.  Its all gotta be redone properly at a later date!
Check out my warpage, need to sort that
And a side shot, she\'s blue  ;D
DRAGON
I love that original fan belt box, antique Mazda parts are cool. Great project, thanks for the write up.
David Nock (RIP)
Yep, same as all above - very impressed and thanks for a great write up.
Sadly Missed
2002Gimp
Currently in me Garage:
:cool
Brett
Will it be stock or ported? :wave
Brap Brap Brap Brap
2002Gimp
Since i dont have a clue how the damn thing works, it\'ll be going in stock...
Brett
That\'s easy - it goes around around.  The smaller bit goes around 3 times and the bigger bits only go around once.
HTH :Giggle
Brap Brap Brap Brap
