need intercooler
Started by cowboy, August 18, 2008, 02:57:04 AM
cowboy
need inter cooler 4 my rx 1992 wot u think i should get and how much do they cost
hairyhoover
Madbadweasel
I Need a FMIC desperately....
cowboy
Quote from: hairyhoover;525188my fmic! :)
wot u got pics? and how much
Lil-Steve
It really depends on what you are after from the car, there are three options:
SMIC (Side mount) : Sits in the place of the original, great for mild power increase and daily driving.The problem is the raditor will warm it up when you are going slowly on hot day or if you are stuck in traffic.
FMIC (Front Mount) : For out and out power (drag racing) sits directly in the air flow at the front of the car provides the best cooling for the intake charge, but heats the air to the radiator an blocks its airflow; requies specailist piping (most FMIC kits come with this)
V-Mount IC : Imagine the front the car is pointing left and you are looking at it from the side the v-mount is like this > with the upper line being the IC and the lower line the rad. Its expensive but the best for track racing and extended high speed driving, as neither blocks the others airflow also requires the most work to fit. It\'s also very cool and people will be jealous! ;)
If you are intersted in any of the above please feel free to PM me.
Lil-Steve is.... loving it when a plan comes together.
karl_tate
i thought SMIC was standard mount instead of side?? :p
____________________
XBOX GAMERS TAG --- tatey1985
gyles18
ive got a re-worx v-mount intercooler and it works very well....its very large though and wasnt cheap......but then you get what you pay for......
pic...
cowboy
i know ther cheap 1 on ebay r they as good as the hks 1s
sorry am new to all this
and ive got a acr airbox woudl and hks or apexi 1 be better
and ive got a apexi fc on it bet need a commader for it does any 1 know where i can get hold of 1 to
sorry dont like to be a pain just like to know my stuff and not learn the hard way
cheers 4 and replys
Jit
well if you want something thats good an easy enough to install, id go for a stock mount IC. They work really well. Ive got an RE-Amemiya SMIC on my car which will be coming off shortly. Works really well on my car and loads of people still use them with single turbos etc. Also really easy to install and doesnt require you to remove your bumper and/or make up new pipes.
