Where to buy: aux secondry injector ports??
Started by Jono FD3, July 20, 2008, 10:58:14 PM
Jono FD3
Guys... getting an engine built soon & I\'m looking at dropping in a second set of secondrys........ injectors are not a problem, but I need to know where I can get the ports them selves, so I can weld them in the manifold!!
Jono
Best bet would be to take an old rotor housing along to a machine shop and ask them to replicate an injector seat into two weldable bosses out of a couple of lumps of alloy,
DRAGON
Quote from: clive;518477Best bet would be to take an old rotor housing along to a machine shop and ask them to replicate an injector seat into two weldable bosses out of a couple of lumps of alloy,
The secondary injectors are not in the rotor housings?
Jono, the way I have done it is to weld a secondary rail into the LIM/UIM. Then a twin pump system, using the purge line.
Monday morning early, lets amend that to take a lower inlet manifold to the machine shop,
Doh, not like I\'ve never seen one of these things before !
One other way is what Chris from Bournemouth apparently did and that is make up a sandwich plate that sat between the upper and lower inlet to take extra injectors,
BTW had this conversation the other day and advised the guy to perhaps look at 1,000 injectors to sit in the primary\'s to go with his 1600 secondaries which is more than enough for most,
Also bear in mind that by only using four 1,000cc injectors Chris Impeys car got into the 10\'s at last years Rotorstock
